washdown disconnect
You need at least UL/NEMA4 for washdown, UL/NEMA4X adds corrosion resistance which is better for cleaning solutions.
Many of the smaller non-metallic IEC style disconnects are not UL listed for anything past UL/NEMA 1 or maybe UL/NEMA 12, even though they are IP65 rated. Most of the time this is because of the plastic not passing UL flame/smoke tests.
I have seen Hubbell disconnects in many dairies.
I design a lot of panels for use in washdown applications. A lot of these have the 1/8 DIN Omron or Red Lion panel meters to read RPM etc. They...
1,002
Have an usual application where I need a 24VDC sub-fractional gearmotor in a wash-down or corrosion resistant finish but can't seem to come up...
1,510
What really is a Wash-down Rating ? Is this a separate rating from like a NEMA 4x ? I often hear wash-down terminology thrown around but does...
3,684
Hi All Has anyone ever come across a washdown rated Estop? Google is failing me!
2,767
Found this article on washdown mounting etc. The question has come up on this site from time to time.
1,584
