waste water treatment
Charbel
Jan 2012
Beirut
307
Dear,
I am using a low level switch in waste water tank interlocked with pump, this level will stop the pump in case of low level in the tank, specially in manual mode.
will this level switch break overtime due to contact with the sewage? what is your experience in this? if proper material is used, i believe this will be ok... what do u think?
There is an alternative for protecting the pump in case of low level in manual mode, stop the pump based on current supervising... what do you think? will it be too late to wait for the current to rise in order to stop the pump?
Which option, you think is most suitable?
thanks!
charbel
Float switches can be very reliable. There are a great many available in stainless steel and non-metallic construction that are specifically designed for sewage pump station wet wells. You can find some examples here:
http://search.usabluebook.com/search?keywords=float+switches
I suggest you talk to your pump supplier - they probably have a good deal of experience. One additional caution: raw sewage wet wells tend to generate methane from the action of anaerobic bacteria. Codes often require intrinsic safety barriers between the float switch and the control components:
http://www.usabluebook.com/p-271852-intrinsically-safe-relay-latching-24vacvdc.aspx
There is nothing wrong with using current monitoring as a secondary protection mode if you distrust the float switch.
Hey all, Question regarding waste water treatment control standards. Without too much context, i am wondering if waste water for some reason...
2,410
Hello everyone, In a conversation with a major drive distributor MCCs and Kiosks were frequently mentioned and I had no clue what he meant by a...
1,144
This system is a 1769-L32E PLC/SCADA, with three 1794-AENT flex bus remote I/O stations, over Ethernet. This system has been in place for 10 (or...
1,952
I have a customer that needs to start logging their waster water system at the demand of the county. They need to report quarterly the daily...
4,254
Dear experts I am trying to learn about the water / waste water process automation using PLC , do you have any plc application (For any type of...
4,267
