TConnolly
Is the customer using glycol because he is operating the chiller at less than 45F (8C)?
Or is the glycol to combat corrosion?
If it is for corriosion purposes there are much better ways to do this. Glycol significanly lowers the specific heat of the coolant, so while it also lowers the freezing point, it makes the chiller much less efficient. Corrosion inhibitors such as Boron Nitride solutions however do not radically alter the specific heat of the coolant solution, and concentrations can be monitored with a inexpensive PH meter.
