I am currently looking for corrosion and moisture protection sprays
that are suitable for food grade applications. I deal with a high washdown plant that typically uses 180 psi spray system for cleanup.
The other problem is the normally high humidity 80% and up under cool air conditions. dielectric grease works somewhat but due to the high pressure washdown it isn't sufficient. any suggestions or links would
help immensely.
help immensely.
