water tight ethernet (rj45) connector
sweetjohnny
Feb 2012
Iowa
55
I have a couple pieces of moveable equipment, I would like to put these on my network. Question is, has anyone here used water tight rj45 connectors? If so did you have luck with them? what brand did you use? This equipment will not be moved alot maybe twice a month, in short they wont be plugged in and unplugged multiple times a day.
How water tight does it have to be? I've always liked the Harting HAN-Modular (PDF Catalog download link) style connectors, and they are IP65 rated. They also hold up to a bit of physical abuse, pretty sturdy on the outside. Inside you can put numerous different things including RJ45 Modules. And I think it is a pretty standard housing dimension across the industry.
86
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
636
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
606
Hi all, i have an application in which i need to read the water level in a 1 1/2" diameter tube that is 24 in. tall. the sensor will be mounted...
27
1,982
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,292
