Wavenis to Modbus convertor
jaconovo
Jan 2014
Bloemfontein
Hi everyone.
I have the need to read the totalized flow from a mechanical flow meter with a RTU to my SCADA once a day. The principal would be to have a reed switch or opto coupler on the flow meter giving pulses to a device counting the pulses and displaying the totalised flow. Simple enough, but I cannot find a maker of flow meters that have a device from which I can read the totalised flow with Modbus or equivalent protocall. I do not want to create a totalised flow on the RTU as this will create reliability issues when the RTU is off for any reason. As I understand most reputable flow meters have products that can display and transmit the totalised flow, usually with wavenis protocall. Due to the remoteness of these applications this is not an option and manually reading the meters also. Anybody have any ideas for me? I heard of a Webdyn Bridge Wavenis to Modbus converter, have anyone used this before?
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
61
104
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
256
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
187
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
51
