Webserver with opc
aradhonline
Nov 2009
Dubai
62
I have kepserver and visual basic running in my small plant . And i have taken an internet connection recently.What is the best and cheap method so that i can monitor values from a remote place through internet . HTML is enough and without any creepy graphics..:unsure:
What kind of PLC are you connecting to? Are you running an OPC-UA version of Kepserver?
The Ignition OPC-UA server is free. It includes a web based "quick client" that allows you to read and write PLC registers from your web browser. This can provide a good way for you as an integrator/admin/etc to check up on your system. I wouldn't recommend using it for the rest of the staff, low level operators, etc. Ignition natively supports AB ethernet and modbus only - that's why I asked about the UA version of Kepserver.
No we are still having OPC-DA kepserver . I have also tried ignition ..But it was not free ..Is the client version free of cost ?
Ignition has free components. The OPC-UA server is free if you're connecting to a compatible device. What kind of PLC are you connecting to?
Once you connect, the "gateway" (configuration web page) has a built in "quick client" that allows you to read/write PLC values from your web browser.
Does anyone know if it is possible to only publish certain pages to the webserver? The only thing I can find to limit users somehow is to restrict...
358
I updated a ML1400/B from v10 FW to v21 FW a while back and today I see that the webpage no longer comes up at all. I read the notes that said a...
1,245
Hi All I am planning a small project as follows: 4 transistor output (high transition count 500/Hr) 4 general output (1-2 cycles/day) 4 Digital...
2,093
Goodevening all... I have a Redlion PTV and Graphite with built in webserver... I can create the simple default.htm page... drag in tags to...
1,912
I've recently upgraded from a Red Lion G306A HMI to a Red Lion Graphite G09, and have converted the program over using Crimson. Everything works...
2,347
