Weird Redlion G308 problem.
robinsheehy
Jun 2010
Mackay
I use the G306 a lot for various products that my company builds, but this is the first time using the G308.
It is a simple program that uses 2 ADAM units for the IO. The 4017+ and the 4055. Both using MODBUS via RS485 on the same network.
I wrote the program and in testing found that the results from the 4017+ would drop out every 10-30 seconds e.g. "---" on screen.
The final step of looking for this was to write a bare bones from scratch program that just read the results I want and displays them on screen. I did this for both Crimson 2.0 and Crimson 3.0 and both the G306 and G308. The up shot of which is this.
The program always has drop out issues on the G308 but never on the G306. I even tried just making a convert of the G306 code the worked to G308, but the problem remained.
Has anybody else had similar issues with the G308? And maybe have fixes?
My other thought was to use the modules with the ADAM driver but the modules I use are not listed :(
(I have attached the Crimson 3.0 CD3 files that exhibit the issue if that helps)
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
166
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
770
Good morning. I'm doing a rehab and I need to recycle some part of the old code that won't change and that I need. This is a calculation that...
22
1,390
I'm trying to figure out a weird behavior I'm seeing in my CCW program. It's for controlling a gas polarizer (for medical imaging). I'm using an...
472
I'm trying to figure out some weird behavior I'm seeing in one of my programs. This should be fairly straightforward - except that it's not...
958
