russrmartin
A dummy's explanation
I'm pretty limited with encoder troubleshooting. We have them all over the place here, but I've never seen a problem with one. Can someone elaborate exactly how you would use the oscilloscope to troubleshoot this? Particularly, what leads out of the encoder would you check, and shouldn't the encoder be turned to watch the pulse? I guess my main question is, which leads do you look at, and what do you expect to see when the encoder is not moving, further, if you are looking at a steady signal, why will a good VOM not give you the same information? Thanks.
Russ
Russ
