What are I missing?
poiuy
Oct 2003
47
Can someone tell me why this ladder logic doesn't seem to work?
I can toggle each of the latching bits individually, but when I toggle the input bit, it doesnt energize the latching outputs.
Ah, right. I'm a college student (in case you didn't guess) and this is the first major project I've done on my own. I have to have a main ladder that just calls the other ladders, right? Does it matter which ladder number it is? I'm using a 5/01.
Your main ladder file is file 2. At this stage of your career, you'll save yourself a lot of headaches if you simply call all subroutine files from file 2.
The 5/01 will let you nest subroutines up to four levels (I think) deep. That is, ladder file 2 can call file 20, which can call file 12, which can call file 21, etc.
2 oz vodka to 6 oz OJ. I dont drink vodka, so I just guessed. My girlfriend is the screwdriver fan, vodka makes me sick.
I'm not sure but If you build your ladder like me you do this
----|i:0/0|------------------------------------------(b3:0/0)
If this de case, you cannot toggle b3:0/0 because I:0/0 set it to off at each scan. You be able to toggle i:0/0.
Hi Guys
A quick look. if you show the ladder correctly with the correct addresses.
The the bit you want to use to toggle the latch on is wrong their is NO B9 file in the processor file 9 is resueved for a routing table
they can be B3 or any file above file 9
Hi Guys
Sure about that? I created b9, so I know there is one, and the program is running fine. I forgot to make ladder 2 call the subroutines, that's all.
The input is from a panelview, so I didn't do that, although I've seen it done with discrete input modules. Should I do that for the panelview inputs? It seems redundant.
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics show not only blower...
126
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
109
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
311
Hi guys, got one problem PLC model fp-xh c60t and HMI model TG765S-MT I've encountered an issue which is the recipe file went missing if i swtich...
89
I have a modicon quantum plc and and i have a stu file that have the program but when trying to download it to the plc. it gives not built and...
84
