What do I need?
daveford
Apr 2005
I am new at this PLC game. I have just picked up an AB SLC500 system for my Zinc line. I have a P2 power supply, L532 16K processor, A10 rack w/3 IA16 inputs, 2 OA16 outputs, 1 OB16 output, and a 600 Panelview Device net 2711-B6C10. Do I need a scanner and/or a AIC to make this panelview work or can I go direct from the processor to the panelview? I know I need the Panelbuilder software, but do I need other items? I have a 1200E-2711E-T12C6 Panelview comming later. Which is the best to use? Appreciate any help to this novice. Thanks.
Why doing a devicenet Panelview? You will then need a devicenet "scanner" like 1747-SDN and the RSNetworx Devicenet software. L532 is a SLC 5/03. You can do direct connect from 5/03 to a DF1 or DH485 Panelview using a simple straight through serial cable.
1200E PV is an obsolete product, I believe, you need 1400E programming software for that. I would not touch it.
I am no expert, but as a casual observer, I believe that your first step should be to hire a PLC integrator.
I may be wrong but doesnt that PV600 unit also have a RS232 port? It may be possible to direct connect using RS232 and not worry about the devicenet.
The DeviceNet PanelView will only communicate with the PLC via DeviceNet. The RS-232 port is for printer connection. Most of the the PanelViews with a printer port will allow you to configure the printer port for upload/download, but not direct comms with the PLC.
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
101
67
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
309
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
376
194
