What does it take to Replace Siemens Modules?
hgg
Aug 2009
Awassa
17
Hello all, I need your usual guide and help.
I have applications that use different Siemens S7-300/400 modules. I want to order spare parts for all incase of failure. But it is costly to order each and individual modulers. So i need your advice before i order the spares.When i right click-replace object in the HW configuration, i don't get the options i want to replace with. So
1. can i change CPU315-2DP with CPU317-2PN/DP or other CPUs not listed in the compatible list? If yes, what are the parameters to change?
2.can i change SM 331 AI8*13 bit by SM 331 AI8*14 bit or SM 331 AI8*12 bit? what are the drawbacks?
3. can i change SM with DO with another one with SM Di/DO but leave the DIs unused?
Thank you very much for all your help in advance.
This is real generic question with too many variables like the multitudes of different PLC's. It's just for ghits and siggles, for I think for a...
23
11,423
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
42
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
36
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
122
