What does XA stand for in P&ID
A_G
Jul 2014
MA
370
Anyone know what XA stands for in a P&ID drawing? The drawing legend does not say
AustralIan is correct. Just want to expand on this a little. X is user defined, but rarely is it actually defined on the drawing. Most of the time X serves as a "Catch All" for everything that is not normal defined in P&ID's. Things like Pressure (P), Temperature (T) and Flow (F) are self evident but a X may be many different things depending on the device. That is why it will not be defined on the drawing.
As AustralIan and Bullzi have indicated, the XA means User defined Alarm. This is defined by ISA-5.0-1984(R1992) Instrumentation Symbols & Identification; a standard for the process industry to identify symbols on a P&ID; I would attach the Table 1 from this standard, which contains a complete (?) list of the identification letters and their use, but it is copyrighted. Basically, the standard defines a 2, 3 or 4 letter descriptor with a numeric identifier. This is a widely accepted standard; it can be purchased from ISA - The International Society of Automation at http://isa.org , or downloaded if you are a member.
Note: ISA was the Instrument Society of America way back when I joined
I've got a bunch of alarms in GT designer3 and they are "mapped" to M parameters, eg M277. What does M signify? Thanks
2,271
Complete Novice here - I understand that GXDev is for writing the ladder logic (PLC code). I understand that GTDesigner is for defining the HMI...
1,868
Good Morning , Just wondering . I understand that millivolts change when temperature rises . Does resistance change also ? Thanks in...
2,562
On the Siemens s7300 I/O there is a schematic on the the inside of the cover, what does the M stand for?
5,694
