What encoder to use for Kinetix 6000
binarramil
Jun 2013
marikina
Hello Guys. I need help. what would be the best model of SICK Hyperface encoder to use for Kinetix 6000., please suggest. tnx in advance for your replies.
First, a bit of Forum etiquette: If you are asking a new question, please create just one new thread. You posted to five other very old threads that only happened to refer to Kinetix 6000 and feedback topics, and resurrecting those threads to ask a different question is not helpful to the Forum.
Kinetix 6000 multi-axis servo controllers are a fairly mature motion control product, and they support several types of feedback, including Stegmann Hiperface. Hiperface encoders are supported both for motor feedback and for auxiliary encoder inputs.
Both the single-turn SRS and multi-turn SRM type encoders are supported by Kinetix 6000 motion controllers.
I do know that the XKS wire-draw string encoder, even though it's a Hiperface product, does not work with Kinetix 6000.
There are dozens of different encoder part numbers made by SICK that support Hiperface SRS or SRM. Any of them will work with Kinetix 6000, so there is no single 'best' encoder part number.
There are three families of Kinetix 6000 controllers; 6000, 6200, and 6500. Any of them will work with Hiperface SRS or SRM encoders.
Sorry sir for the bad behavior. I'm just new in this kind of forum thing. Anyway sir, thank you for the information regarding encoders.
Hallo Folks ! I started a Project with CL5000 and Kinetix 6000. I want to install a Absolute Single Turn Encoder on the Aux Encoder Input of one...
4,184
We are pretty new at servo motion and control. We have used a Kinetix 300 controlled by an absolute encoder wired directly to the drive, but have...
5,186
Hi, Can anybody recommend an Absolute encoder to use on the Auxiliary input of the Kinetix 6000? The AB unit is a bit expensive. Thanks, Tim
2,007
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
307
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
371
