What is the catalog number for Siemens PLC S7-400? Please advise.
flyers
Sep 2006
Amk
295
Hi guys,
Any siemens PLC user here can advise me what is the catalog number for EEPROM 16Mbyte for Siemens PLC S7-400?
I check from the manual, is this 6ES7 952-1KS00-0AA0?
Thank you.
dchartier said:
Hello flyers;
Here is the desciption found in Siemens' online Mall:
Here is a link to the A&D Mall, if you need to search for other equipment:
https://mall.ad.siemens.com/WW/guest/index.asp?aktPrim=0&lang=en&nodeID=9109999&foldersopen=-854-855-2837-&jumpto=2837
Hope this helps,
Daniel Chartier
Is flash card same as eeprom? it's something like AB ControlLogix, which is using a memory card to backup the program & data? S7-400 no longer use a modular base eeprom like AB SLC 500 (1747-M13), right?
dchartier said:
Hello flyers;
Hope this helps,
Daniel Chartier
Do I need any additional module to let the eprom to work with the S7-400 CPU? Or it's like AB SLC FlashProm, just get the EPROM & plug it into the pre-assigned slot?
Thank you.
Hello flyers;
The following picture should explain things:
Hope this helps,
Daniel Chartier
By the way, you can locate all the necessary domunets for the S7-400 platform on Siemens' support website:
http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&changelang=true&aktprim=0&siteid=cseus&lang=en
Hi PLC experts :) I’m working on a project in studio 5000 Logix designer with several servo motors, I'm trying to set the properties for them...
827
We have a PanelView 1000 that has died. It has a catalog number of 2711-T10C20X Series F. We found a replacement, but the catalog number is...
2,010
Hi, In RSLogix 5000 i am configuring the Axis properties. Under the Drive/Motor tab i am trying to select the motor catalog number, but am not...
4,431
Anyone know the catalog number for ordering Ultraware software to use for interface with AB Ultra 1500,3000 and 5000 drives Thanks
3,501
Hello. I am struggling with this and it seems it is in from of my eyes but I still don't get it. In Logix 5000 catalog I have registered the...
1,560
