What use does the S7-1200, S7-1500 have?
I need to know what exactly can I do with these two new simatic CPUs?
These are not CPUs but entire families of PLCs. Best is to go to the Siemens website and look into the data. This question is way too open to get a decent answer over here.
Kind regards,
Hello people.Thank you in advance. Below is a java application which I try to communicate my java application with ml 1200 through the Modbus...
3,845
Dear Members, I'm facing a strange problem with a micro-automation project done in Siemens S7-1200 PLC. The small program I wrote compiles...
13,162
Hello everyone, One of my customers asked if Micrologix has opto isolator on the outputs? Does it? Thanks!
3,577
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
42
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
34
