Where these data block stored in STEP 7?
Learn3rH
Dec 2016
HD
In TIA portal v13 where is in project file information about data block, function code block are stored ? Thanks
What "information" do you mean ?
If you mean properties of the blocks, right-click on a block in the project tree, and then select "properties" in the pop-up menu that appears.
If you mean size of code and data memory, then highligt the CPU in the project tree, and in the menu bar, open "Tools" ... "resources".
I means those block information will stores in which DLL ? then when the project loaded the information is also loaded in the main app !
Your question(s) are not clear.
So, lets try this from a different direction - What do you want to do?
Hello friends. Please, can you help me on where I can buy Fuji Electric Hakko HMI and it's programming software and its data transfer cable...
1,829
I have a 1734-AENT configured in RSlogix 5000 with an IA4 module. I was expecting to see a controller tag something like FS1:1:I.Ch0Data, but I...
2,200
I need a explanation of how data is translated between different devices. Where is this data being stored? What different languages of information...
1,811
I'm having a tough time trying to get used to old habbits in S7 and them not being the same in TIA portal. First impressions are its cr*p what...
8,387
This is baffling me. We're having an indication at the panel view that says "no flow" at the operator's panel. I'm looking in the plc project and...
5,480
