Which protocal does the Omron CPM1A use?
GMH
Apr 2009
Alberta
Hi does anyone know which protocal the cpm2a plc uses? I want to interface it with the C-more micro and C-more full color screens. Also has anyone tried this if so is it fairly easy to learn this will be my first time I've tried this. Any helpful feedback would be nice thanks
Looks like you'll be using the Host Link protocol. The C-more help shows you the wiring needed to build your own cable. Looks like Omron uses pin 9 for ground instead of 5, so there's probably no standard cables that will work for you.
My Tech and I were talking about IO-Link and HART today. I was telling him that HART is an older and more complicated Protocal than IO-Link. I...
2,738
Hello all, I am currently attending Oklahoma State University Institute of Technology and I am in my finial semester. I am working on a capstone...
4,712
42
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
34
