Who changed it????
ceilingwalker
Mar 2010
Phoenix, AZ
1,587
Is there any way to determine who and when a change was made to a program? I am dog-tired of changes being made to running systems, getting everyone in the room, and no one admits to making the change. I am working on getting FT security so that people will be required to input their password to access the logic but, until then, is there at least a way to know when (date/time stamp) of when a specific change was made? For example: somene loves AFI's and branch-shorts for permanent repairs, where I work. I would love to find out who is doing it. I don't subscribe the the Gremlin theory. Thanks
Doesn't the file properties give you a last modified date? And sometimes a "modified by" depending how your IT is setup.
Maybe a cultural change is needed? Changes should have a revision note with author, no matter the size of the change.
Are we to assume Allen Bradley Logix 5000 controllers?...
If so, have a read here of Chapter 3 - Controller Logging for a basic method (with exceptions) which will not involve auditing software, if you are not ready or are not going to make that leap later...
Logix5000 Controllers Information and Status Programming Manual
It can log many things including change detection with username, workstation, and FT User, if setup, and other details. You can program it to log automatically to removable media, if available.
I'll let you read for yourself.
Regards,
George
Regards,
George
Thanks George
Just had the anomaly. Stamping press, 20 years old, SLC5/04 CPU with EEPROM memory module. The customer says suddenly a couple days ago they...
25
9,638
Hello, I am currently trying to control a motor in my plc. I've made a simple on/off button logic. And it works pretty well, when i press the...
25
6,096
We have just recently had an "outside" organisation upgrade our AB SLC PLC with a Controllogix. In doing so they have changed all of the messages...
1,807
So I'm working with a machine that has a parameter on the HMI (EZ Automation EZ-T10C-F)that writes back to F11:17 on the PLC (SLC 5/04). The...
5,390
Hi Guys, The title basically says it all. We had a PC failure last week and after having the backup restored, and getting all the config correct...
2,074
