Why are my controller tags grayed out in Logix Designer
m3rheino
Jan 2021
Nashville
I have an existing file that shows most of my controller tags as grayed out. Just want to tweak some of the tag names.
1756-L84ES
GuardLogix 5580 Safety Controller
Rev. 32
Offline
Did you purchase the Tag Editor Add-On? (US $1495)
Kidding. Are you under the Monitor Tags or Edit Tags tab?
Not so far from be a real thing when it comes to Saftey edits. AB will let you see it but not touch it. Certainly no safety when it comes to wallet. Sorta nuts, IMO. Also, seems you can delete modules[safety] but not add. Almost like the AB revenue protection program is reaching out to grab you. Beware.
As others have alluded to, certain versions of Logix Designer don't allow editing of safety resources. If you don't have the Pro version, you'll need to either upgrade or buy the safety add-on.
Some might take pot shots at this approach as a revenue-raising exercise, but to me it makes perfect sense. If I had a factory with lots of safety PLC's in it, and lots of maintenance techs and engineers, I'd probably be inclined to deliberately omit the safety add-on from the maintenance technicians computers, and install it only on the engineers computers. Maintenance technicians are always the ones being leaned on to "get it running NOW", and I'd rather that they don't get put in a position where they're being pressured to mess with safety code for the sake of production. Much better for them to turn around and say "it's a safety fault, I can change the guard switch but if you want to edit the safety code you'll have to escalate this to the engineers". Protects the maintenance techs, protects the operators of the dangerous equipment, protects the short-sighted production manager who would have forced an underling into doing something dangerous if they could have.
That aside, the other question is, is the processor safety locked? If it's safety locked, even if you do have the safety editor, you won't be able to change any safety tags or logic without unlocking the processor. Again, this is by design - once safety code is tested and validated, it's locked and a safety signature is generated. That safety signature covers the backside of whoever programmed it. I program safety PLC's regularly, and for each and every one, the safety signature as I left it is recorded. If someone gets hurt on that machine, and the safety signature or its timestamp don't match the one I left in there, I'm not on the hook.
Your argument breaks down completely when you look at the fact that other than ladder no other PLC language is added out of the box. It breaks down even further when some of the instructions the PLC is well capable of performing are only available in certain languages.
You do have a point about not allowing anyone not competent to be anywhere near a safety system, but it's not because of Rockwell's concern for your plant safety. It's a revenue stream.
Thanks for your input. The PLC is offline, but I just found out that I can place the safety application in a safety-locked state regardless of being online or offline. I will investigate.
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
135
I am trying to get all of the controller tags from a RSLogix 5000 project into an excel spreadsheet along with the style, data type and...
1,472
I have one project in CCW where I have a micro820 controller and a panelview pv800. I also have another controller in the same network micro820...
1,730
Good Morning , I have a bank of Kinetix 6000 Drives that I'm getting faults on. I took notice in my ControlLogix , Controller Tags for the...
3,738
I any other program I've delt with simply typing a tag name into a XIO/XIC/OTE/etc and right click, create tag.. creates it as a controller tag...
2,034
