ebalarde
I was wondering if anybody was reading.
I taught a class once, and, when covering the elements of the system, I mentioned that there are INPUT modules, and OUTPUT modules; digital and analog. I also said (then..not now) that all systems have some combination of INPUT and OUTPUT modules.
Safe, right?
Not this class.
S: "Jeff, we have a system at work that only has input modules."
Me: "That's hard to believe. It's like a lawn mower that won't cut your foot off....it doesn't cut grass either. What do you use it for?"
S: "Troubleshooting."
[It turns out that it was connected to a relay-controlled machine, and all that it did was to use internal memory bits to track the status of various inputs from relay contacts and monitoring of relay coil energization status. It was on a machine that the OEM refused to use programmable controllers on....an amusement park ride; in this case, a roller coaster.]
So, as I teach, just because _you_ haven't seen one, doesn't mean that they're not out there, somewhere.
But they were still dealing with OUTPUTS, though not physical ones. The troubleshooting data is the OUTPUT.
They needed to figure out what data they needed (OUTPUTS) before deciding which signals to bring to the INPUT modules.
