first : i thank you for your help and for your continue with me
second : yes , i ask the same questions , but the main reason is :
yesterday , you agreed with me at post 54 and said to me :
" You are correct. Also, you get 100% for spelling. Your English grammar is almost perfect! I am impressed "
when i said before that:
" also if i take R ( phase conductor ), S ( phase conductor ) and T ( phase conductor ), - either from star connection or delta connection - and applied R , S , and T to a three phase load , i must say it is three single phase voltage sources - not say three phases voltage source - with three phase conductors or with three hot wires "
but after more posts , i found that is not correct !!
you can read post 75 which is :
" I agree that if you had three separate single phase sources (3X2 wires), you could refer to them as
" three single phase voltage sources "
I thought you were refering a single three phase source (3 wires) in which case you should be saying
" three phase voltage source "
and also you can read post 85 which is :
" That's "three phase", or more correctly, "three voltage sources with their frequency out of phase". Note there are three voltage curves. Got it?
Now, for "three single phase", the three lines would be on the same curve; you would see one line of frequency rather than three. There is no staggering of frequency on a "three single phase" arrangement."
and also you can read post 86 which is :
" 3 phase voltage has (1) set of (3) conductors, like A-B-C.
3 single phase voltages have (3) sets of (2) conductors, like A-B, B-C, C-A or A-C, A-C, and A-C. Notice how the first set can be combined into a 3 phase system (A-B-C), but the second set cannot "
so i want to modify the data which i take from you and to be check for it
there is no doubt i benefit from you at this discussion and all your disccusions with me
and also i thank you again for your help
that is enough for this forum for me and i do not ask any question again for this forum !!
thanks all
