Wild and weird timer in PL7
oxykill
Jan 2013
Quebec
Hi there every one,
I'm working in a PL7 program, (TSX 573623) the existing timer (FTON or %Tm) are working good.
The problem is : when I add a new timer, it doesn't work at it should (FTON the %md use to calculate is stall and the %mw to show the current value count in negative) and for the %Tm, nothing work, input on and timer doing nothing !
Just zip and post the program. Maybe someone on the forum can spot the problem.
I cannot share the program for legal right. ... Sorry
But : i'm also wondering : the PLC memory is almost full, it stay about 1.6% free space could it be critical ?
I never saw this problem on any other project, it's very weird.
Able to create time, but timer doesn't work at all, no time count when activated or wild negative count ...
Windows 10, x86_64, RSLogix Micro Starter Lite RSLogix Emulate 500 6.00.00.07 (CPR9) RSLinx Classic 2.57.00.14 CPR 9 SR 3 See the attached ZIP...
41
10,916
3,358
HI All, I am trying to do some repeat logic on and existing code SLC504. The code is the same just the addresses are different, I have created...
3,357
I am using a ML1400 to count the RPM of several items. They all use the same math to determine the RPM after 10 counts of the counter. The one...
3,267
http://arstechnica.com/security/news/2010/09/stuxnet-worm-attacks-industrial-targets-could-be-aimed-at-iran.ars Great, all I need is to start...
3,059
