Win 2000 Pro Start Problem
driller
Jan 2004
Tulsa, Oklahoma
When I start my computer, before or after I put in my password and the computer starts, their's a picture that was downloaded off the internet that I can't remove. Also the same picture shows up when I shut down my computer. I have Win 2000 Pro, thanks "DRILLER"
Look in your windows folder for logos.sys (startup logo bmp) and logow.sys (shutdown bmp).
To make them original copy the files off your windows cd. To replace them with your own picture file, it must be the EXACT SAME SIZE, change the name and put in the windows folder to overwrite what is there.
Also look in startup to see if that picture is being loaded from there...right click Start then Explore...Start Menu opens then look in StartUp.
If I didnt explain this correctly please let me know.
Also, check into your "active desktop" setup.
Traditionally, Windows (Win 3.0-Win95) used bitmaps only for desktop backgrounds. What I've seen happen since they decided to add GIF, JPEG, Etc. to the list of acceptable files, is that the LAST bitmap you selected for your desktop will appear until Windows loads the drivers to paste your current background over it.
If you can get through that run-on sentence, you should be clever enough to fix the problem. The quick and dirty method is to find the file you don't want to see and move/rename it. Out of sight, out of mind. Otherwise, I think you may end up digging in the registry...
AK
If the picture is displayed at the same time as the login box. Then its this register value that you have to delete. HKEY_USERS\.DEFAULT\Control Panel\Desktop\Wallpaper
Dear Friends During the Installation of WinCC v 6.0 there was a requirement for installing SQL server 2000(WinCC instanz) . and I dont know about...
15,548
Ok, I've searched and read about W2K and the KTX board. I have been fighting this problem for a while and still losing. When I run Cimplicity I...
1,728
Hi there! We use Adept motion controllers. We program this controller via TCP/IP. With older laptops running win98 we don't have problems. With...
4,938
Hi Everybody, Help needed please. After setting up Allen Bradley 1784-PKTX on a Dell P4 Windows 2000 System and driver properly installed...
17
14,461
Can somebody tell me if there is on the market a program, like STEP 7, that but for S5 - 95U under Win 9x/NT/2000. The DOS version made by SIEMENS...
11,747
