WinCC 7.0 -How to log data which CAN be retrieved
Jul 2007
Kiruna
600
I'm not too well versed in database programming so its something I would rather avoid at this late stage in a project.
I am doing some logging of data in an S7 315 PLC which is used for statisical purposes: No of Cycles each day, weight, drying times, cycle times etc etc
Some data get updated each day and some each cycle. I only hold onto 7 days data to keep memory to a minimum. Now customer has requested that while I display a weeks data on HMI they want to log the old data somehow so they can retrieve it at a later late.
Am I correct in saying that I cannot log to a SQL database without extra licencing for WinCC?
Can anyone please suggest a way of logging this data so I can retrieve with ease if required? There is also a user archive which might be of use.
Well, strictly speaking, no. It's just programming. :)
You can easily write global script code that access any database and insert/read/append data in it as you wish.
From your original post it's unclear what data you want to put where and how do you want to read it later on. Try to explain that in more details.
I have a data log that is setup as a circluar log so the old data will fall off after the file gets so big. 99% of the time the log is getting...
5,079
Hi Guys. When a domain user is logged in (simatic logon erver) both audit trail and alarm logs are working well. but as soon as the user is...
1,497
Hi! I have a pretty awkward problem on my runtime system. It's connected to a s7-1200 and this s7-1200 calculate PartsPerMinute(PPM). Every time...
1,211
How can you tell if it's running? Do I need to open all logs first? I have the same questions as this post. The answers here are in German, or...
1,657
Does anyone have any experience of Alarm Log (for Historical Data) on a Simatic Touch Panel? What I am trying to do is log history to MMC and...
2,870
