WinCC application in different languages
Pandiani
Apr 2005
Tz
718
Hello guys,
I'm not very familiar with WinCC so I was surprised when I saw one small WinCC application that has on one page buttons with diferent language to choose. If you choose "English", every menus and button captions are in English and so forth. It seems like there is some kind of special language script that is loaded every time user press approriate button which change labels and menus.
I know there are couple people here who are experts and I'd like you to share these tips and tricks with use.
If its WinCC Flexible it is very easy. You setup how ever many languages you want and it makes a table of all your text in your project. Then you can save the table out to Excel and have someone convert it over. Import it back in and your done. You have different ways to select the language at runtime. I just have a button that will index through them all.
Siemens has a white paper on how to do all this. I will look for a link.
Try here it should be the Getting Started Power Users. Chapt 7 shows a step by step on how to set it up.
http://support.automation.siemens.com/WW/llisapi.dll/csfetch/18656980/WinCCflexible2005_GettingStarted_PowerUser_e.pdf?func=cslib.csFetch&nodeid=19309685&forcedownload=true
one more edit.
Chapt 8 not 7
Pandiani said:
Hello guys,
Hello Pandiani;
Try looking up "Text Library" from the online help, it will show you the steps to create a multilingual database for all your text messages in your application.
Hope this helps,
Daniel Chartier
Pandiani said:
Hello guys,
Quick reply as it's past time to go home...:D
Left side of the screen, Language settings > Project languages > here you can select how many languages you want to use. (note it does not translate the text for you...:D)
Now a bit down > Language settings > Project texts > This contains all the texts, this can be exported to Excell if you'd like for translating the needed texts.
Create random button > Set it to Graphic button mode > select for graphic a country flag > Events > Click > SetLanguage > Select the language conform to the flag you have chosen > Compile > Download.
Not hard....have fun
Jeebs
Thank you guys for your replies. It is WinCC v6.2. I had WinCC 6.0 demo somewhere. It seems I'll have to learn that since I do maintenance in one power plant for a living. Advanced control theory and modelling is like a hobby.
I'll play with it for a while and let you know how I'm doing...
Dear All Is it possible to have a .net application written in C# to communicate with siemens wincc 7.4 scada explorer? is so what are the...
1,575
Hi everybody.We want to an application via C script.The scenario is ; there is a silo.Goods into the silo and empty when filled.There will be a...
1,313
Greetings i do have and application the is a Siemens PLC and HMI configured by Winccflex the application is integrated , when i want to open the...
1,406
Hello everyone! I would like to ask you a question regarding a SCADA application that is meant to be controlled from distance. I must build...
7,223
Hi All, I have an application in VB.net that converts values from a txt file to OPC Items which can be used in WinCC. The app runs quiet well...
3,222
