Wincc 7.4 C Script application.
tulip
Oct 2005
ist
236
Hi everybody.We want to an application via C script.The scenario is ; there is a silo.Goods into the silo and empty when filled.There will be a table on the screen and there will be 3 columns next to each other.Previous filling,New filling,Last filling.If we choose this silo via a button on screen for filling the current scada date and time will be recorded under the New filling column ( and start silo filling via plc).When the silo is full, Scada the current date and time will be recorded under the Last filling column.The silo is then emptied ( via plc) and is waiting for refilling.If we select the relevant silo button again and start filling.The scada date and time saved under the New filling column will be recorded in the Previous filling column, Current scada time and date will be recorded in the New filling column and the time and date under the Last filling column will be deleted.Is there any experience on this topic?I would like to thank you in advance.
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
63
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
56
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
113
Hello all, In an WinCC Professional v15 application I need to filter the alarms by alarm class, not using the filter button on the toolbar of the...
2,586
Hi! So I have a problem with the VB script part of the TIA portal. I'm no good at scripting but I have a script that is working in WinCC Flexible...
6,003
