WinCC Flexi 2008
mr.bubu
Apr 2010
Cheras
i have a new project to monitor the machine with use wincc..
My problem now How i can set the trend view at wincc to show 24hours trend
another things is how can i make every 24hours it will automatic save in 1 folder is for recording data in a a few months??
Can anybody explain to cause i'm not familiar this HMI software
You need a data log to get the data then display the data log in a trend. Siemens has some "Getting Started with WinCC Flexible" documentation that should show you just how to do this. Do a search on this site and you will find a link.
Hi i m using wincc flexible. i have created a receipes..... i want to give a used defined receipes..........by operator example: i have given 4...
1,527
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
79
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
69
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
85
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
81
