WinCC flexible 2008 logging timing error.
falgunvasava
Jan 2009
gujarat
60
I am logging 25 variables in ODBC server using winCC flexible 2008 runtime and archives.
Our IT engineer is accessing this logged data from MS access and then generating a report using Visual Studio.
Now the problem is the delay in the logging time.
For 1min logging cycle the error is 1 secs every 2 to 3 logging
For 10min logging cycle the error is 4secs every next logging.
For 15min logging cycle the error is 5-7secs every next logging.
For 30min logging cycle the error is 12-13 secs every next logging.
Due to this logging problem the report is not acceptable to the customer.
Now Few are guiding to create the project in winCC Scada rather then in WinCC felxible.
View attachment DRYER_D1010_1min logging.pdf
View attachment DRYER_D1010_10min logging.pdf
View attachment logging delay error.doc
Please help how to correct this problem in WinCC flexible.o_O
Is it MS-Acces who writes time stamp ?
If is, so problem can be Acces itself if Log-file size is big.
If it is so, try with SQL-Server.
Let the timestamp be part of the logged data that is retrieved from the PLC. So the PLC must generate the timestamp by its own internal clock.
thanks for the reply.
i have no idea how to log timestamp with data.
what i have done is simply define the datalog,logging acquisition mode and logging cycle in WinCC flexible for the tag which i wanted to log.
how can the PLC timestamp be included in the Log?
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
268
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
110
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,479
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,288
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,851
