WinCC Flexible Recipe/Runtime
ylade
Sep 2007
Ireland
23
Hi All,
I am currently programming WinCC Flex Advanced for a PC that I will be putting on a runtime license. This willl be recipe based and I was until this morning using the runtime simulator. However, the system is now saying I need a license for Recipes. I was holding off in purchasing the runtime license until nearer the commissioning as I do not know how many tags I will have? I was under the impression that the simulator allowed one to test everything?
Cheers JesperMP,
I was prob always getting the message but I am currently importing in screen objects from an old OP35 and now I have numerous errors 'Duplicate tag name XXX in project'. Seems to be a bug as there are no duplicate tags in there. THis is what is preventing the the runtime from starting.
In relation to the existing function within Protool there was an existing function there 'Select Data Record' which allowed the user to select their choice of recipe. I cannot find a similar function within WinCC?
When you copy from one project to another use Flat Copy. This should help with your problems.
Hello I'm looking for a way to do the following but i don't know if it's possible.. I use Wincc flexible runtime PC i use the recipes as...
7,024
Hi all Can anyone help me how can disable box of recipe to ask save pls look at picture attach. I dont want it appear and dont want it auto save...
1,842
Hello, I'm using recipe to save some cycle time information for a production line. Everithing works goods,i can save the recipe and all my...
1,864
Hi guys, I need a solution about recipes in Wincc Flexible. For the purpose of automatic production sequence, I want the transition of data...
2,144
hello everyone i am using tp177b,my customer doesn't want to enter the recipe in the default format of scrolling down and entering each data in...
3,287
