wincc flexible - tag savings
apetkov5
Aug 2007
x
101
Dear all,
I nead some experienced situation answer :)
I have wincc flexible rt connected to plc
db in plc looks like this:
db100.dbx0.0 - one
db100.dbx0.1 - two
db100.dbx0.2 - three
db100.dbx0.3 - four
db100.dbx0.4 - five
db100.dbx0.5 - six
db100.dbx0.6 - seven
db100.dbx0.7 - eight
db100.dbx1.0 - nine
db100.dbx1.1 - ten
At wincc flexible rt i have screen with 10 symbol output fields, each of them filled with two state text list.
To save tag quantity i plan to use one tag DB100.DBD0, put it in all 10 symbol output fields but change "bit number".
So, two state text list in field 1 will be described as tag DB100.DBD0, bit number 1
two state text list in field 2 will be described as tag DB100.DBD0, bit number 2 ..... etc (until field 10 with bit number 10).
My question is can i count bit numbers as next:
db100.dbx0.0 - one ....... bitnumber 0
db100.dbx0.1 - two ....... bitnumber 1
db100.dbx0.2 - three ..... bitnumber 2
db100.dbx0.3 - four ...... bitnumber 3
db100.dbx0.4 - five ...... bitnumber 4
db100.dbx0.5 - six ....... bitnumber 5
db100.dbx0.6 - seven ..... bitnumber 6
db100.dbx0.7 - eight ..... bitnumber 7
db100.dbx1.0 - nine ...... bitnumber 8
db100.dbx1.1 - ten ....... bitnumber 9
...etc
My understanding is that 0.0 will actually be bit 8, 0.7 will be 15, and 1.0 will be bit 0.
Other than that, though, I think what you're trying to do should work.
Hello, I am using WinCC Flex 2005 and I want to configure a button. If you look at the picture below, on release of the button(which is named...
1,397
I am trying to find out if there is a way to "read" the tag comments in WinCC Flex 2008 (SP3) during runtime. I'm using WinCC Runtime on normal...
3,864
hello. How can i know that each "tag" has been used in which screen in a wincc flexible project? best regards.
3,549
Hi everyone, I'm writing an application for a machine that is supposed to run different auto programs, each consisting of up to 50 steps. Each...
5,326
Hi, I have an existing winCC flexible project that connects to a CPU315-2dp. There is an I/O field on the HMI screen that writes to an internal...
3,024
