wincc flexible trend view of array value's
frank_1988
Apr 2011
Eindhoven
At the moment I’m working on a project to log a PID input (weight sensor) within a sample period of 20ms.
Because Wincc cannot read value's every 20ms,(maximum for the pc is 100ms and max of a screen is 1s) I did make a FB witch put very 20ms a INT value into an 600 INT long array.
In the tags of Wincc flexible I read the db as an array.
I did put 200 small ellipse on my screen and connect them to array[0] -> array[199] when I test the program it is working fine, but the max of tag's on a screen is 400.
Is there a way to edit corner points of an polyline with scripts?
Or can I load the array into a trend view?
Or can I load the array into a data log and then into a trend view?
I hope you can help me,
JesperMP,
Thank you for your very quick replay!
But I don't know how to fill in the 'buffer bit triggered' trend.
Trend buffer: array
Switch buffer: activate?
Bit: 16? because I read a INT
Trend request: array?
Trend transfer1: I cannot select a INT form the array, or the array
I have a array with 600 INT value's witch all the information.
WinCC flexible Trend View Can Show Maximum 8 Trends,What can be done if you want to show more than 8 trends in the same trendview. Can we use any...
7,327
Can anybody know which settings can show for 24hours trending view at wincc flexi 2008.. Just now i can only show a few minute only if i set to a...
5,102
Hello everyone i want to use a trend in wincc flexible with two variables one for x axis and the second for y axis. i have found only with one...
2,240
Dear all Can anybody help for I am using wincc flexible 2007 .In it I configure 20 numbers historical trends.Each trend has seperate tag and...
3,691
Dear all I am using wincc 2007 to log the data. My client wants to see the historical data so that i have configured the trend view to show log...
5,990
