WinCC: function Execution on a signal state change
cheeko
May 2008
KSA
Dear Members,
I need to execute a function(user programmed action) on digital input signal state change. It does not have any graphical object.
How can we refresh a graphic screen using WinCC function? Do we have to use a Win32API?
WinCC: Screen Refresh
control_logic said:
Once you have programmed the script, you can select the "event" property in the tag properties dialog and asign the script to the "change" sub-property.
Thanks for the reply.
Is there any way a can refresh a screen from other screen using any of Wincc Fucntion or Win32 API.
All objects in the refreshed will also be refreshed?
Cheeko
Hi all. I use a function trend control to show X and Y float tag from archive tag. Tags save in tag logging Continuous. I want to use a button to...
1,086
Hello, I am using a KTP 400 compact panel HMI. I am using the Recipe object to create transfer and delete the recipe using its integrated...
1,905
1,666
Dear Experts, Please help me, on how to configure Wincc Slider Cntrl. I want to use this slider as a setpoint for VFD speed, example 0-60Hz...
2,030
Hello everybody, I've just started working with WinCC Flexible and have been trying to get a delay or wait function in a script. I've seen the...
11,189
