WINCC Graphic Runtime freeze when i activate project
Ahmadbasha
Jan 2010
EGYPT
30
i installed 5 times new XP with all drivers on Dell Optiplex 780
Then i installed all drivers which need Net Framework 3
i installed SQL server 2005 then in installed WINCC and the Simatic Net
I locate Project and made Activate ,, Some times it works and many times freeze on Graphic Run time ,
Another problem in same PC ,, when i use another copy of Project , i need to change name of Project Matching with computer Name and work group , then i have to restart WINCC , then WINCC show me error message that problem in Project Database and can't load it
i try to work again without using all drivers ,, same problem
i used alot of copy of same project which is working on my laptop , but some times work on DELL and many times not ,
Any clue about this Crazy computer , i called Guys here work in WINCC and they keep say , i don't know
THANKS for reading and hope you can help
I have a problem when activating projects in WinCC 6.2. Everytime when i active a project, it's working properly, but next time when i activate...
4,825
HEllo, still satruggling with the curse WinCC Unified. See attached picture. I just want to change the fill colour from turqoise to grey and then...
507
Hello everybody! I'm doing dynamically change of graphic object pictures by action script in the WinCC 7.0. And it works only in the chain...
2,708
Hi all, I'm about to learning WinCC in TIA Portal V13 SP1. I have a project that use the some strange graphic picture. Does anyone know where I...
1,995
Hii Can anybody help me for 1. I am using wincc flexible 2005 for PC based scada I have Following problems while developing a) I...
4,152
