WinCC Panel and recipes synced
userxyz
May 2002
any
2,768
Anyone ever tried to use several recipes and sync them with a recordnumber tag ?
Let me explain shortly:
I have a DB in the PLC with names to get rid of the fixed textlist in WinCC Flex. So what I so now in one recipe is setdatarecordtags to PLC when changing the record in the recordview or when saving. So Im buffering in the PLC so that I can see the corresponding names that I resend upwards to the hmi.
But I need an other recipe that does not need to be buffered... so could I make a second recipe and even maybe a third and fourth and sync them ?
Maybe for downloading using a script and use the processing status 4 to check every load ?
Thanks in advance,
Kind regards.
Hi, I've encountered a problem that I wonder if anyone else has? Or maybe I'm to tired and it isn't a problem. I was about to change a KTP700...
4,582
Comfort panel TP1500 It's been running the same program for years and now I'm getting a frequent message across the screen: WinCC Runtime...
20
7,365
Hello I'm looking for a way to do the following but i don't know if it's possible.. I use Wincc TIA V15 comfort panel i use the recipes as...
3,588
Hello, Question about database on a Panel PC.. I had a weird question from a customer, but it's a customer so I have to check if it is possible...
3,313
Hello everyone! In WinCC, when you want to read or write a text file using VB script, it's not the same way to deal with on a PC or on a Panel...
3,548
