WinCC Record login and logout from WebNavigator
grnick50
Nov 2010
Ptolemaida
332
Hello all,
I have a WinCC server where users connect to using Webnavigator. What I want is a method to record at the server the login and logout operations of the WebNavigator users.
Is there a way to do this? Is there an option for this?
Regards
Further investigation shows that there are two system events: 1012400 & 1012401 that do exactly what I need. I test it however and it does not work.
Has anyone used them before?
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
65
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
67
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
145
I am creating a project with WinCC Unified v16 Upd6 (PC runtime) with an S7-1200. The communication is good between the PC and the PLC as I can...
196
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
