WinCC Runtime - multiple monitors - options?
rQx
Oct 2010
Trelleborg
1,051
Hi!
The problem:
A client of mine want to controll his factory from computers (a few)
It's all good and we have WinCC Flexible 2008 Advanced to program it and have already one Runtime installed. However, he want diffrent computers to show diffrent things.
Monitor 1: Control a machine
Monitor 2: Control a machine
monitor 3: Show some statistics
monitor 4: Show some other statistics.
As far as I know I need four licenses for this?
One for each computer?
Is there a way of having these four computers reduced to four monitors connected to one computer and one runtime license, but showing four diffrent screens?
The screens must be able to be controlled independently at each monitor. (We split the mouse and keyboard).
Maybe I need other program? (not wincc)
Some will only display statistics for the factory employees to see and it will be expensive to buy computers and runtime lincenses for every monitor.
I'm thinking of something like this:
attachment.php
Note that the WinCC to which nonuke refers is the full SCADA package, whereas WinCC Flex Runtime is essentially the same runtime the panels have, but running on a PC. The SCADA level system has a lot more options, such as multi-monitor.
As far as I know, WinCC Flex Runtime only supports one monitor, and can only have one session running at a time on each PC. THis means to do 4 monitors, you would need 4 PC's and 4 licenses.
I'm not sure how the licensing would work for the SCADA solution.
When reading the articles that is what I came up with as well unfortunally :/
How does it work if I use a extended desktop? If I have two monitors that is 1366X768, can I make a Runtime project 2724x768 and have it displayed across the two monitors?
You could try it, but I don't think that you would be content with the result. One, I don't think WinCC runtime is completely flexible on the resolution. I think that it only supports certain specified ones.
Also, if it is one big window, then that means both monitors will change if one tries to change the screen. I don't think it is possible to only change part of the screen.
Consider multiple HMI's instead of PC's.
My customer wan't large screen and keyboard/mouse, I think that the HMI's in this range would be expensive?
I see your point, we'll I guess that I can show production results and statistics on LED displays instead of large screens. I will lead the customer in that direction I think.
Hi! Let's say I have a production line that logs the PPM and display it as a trend. If I would like this trend to display one trendline per...
1,705
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
65
when i tried to go online, why its showing lie this
96
We are rewriting software for a Simatic PLC/HMI originally made with TIA Portal V16. We will make use of a library that was developed for V17...
1,607
I have a tia v17 project in laptop. I prepared a PC to be used as HMI. In Tıa projecy there is wincc advance. How can I transfer this wincc...
1,371
