TIA Portal WinCC Advanced runtime licence
xzen
Jun 2006
Oslo
97
We are rewriting software for a Simatic PLC/HMI originally made with TIA Portal V16. We will make use of a library that was developed for V17. Unfortunatly not available in V16. So I’ve just ordered upgrade for my engineering tools from V16 to V18.
The customers HMI is a PC with WinCC Advanced V16 runtime licence. Can he still use the V16 Advanced runtime licence with the new V18 Advanced application?
If you upgrade to a newer runtime (v17 is the newest, even though Portal is at v18 now), you need a new license.
But, you can mark the WinCC Adv system in Portal engineering to use the V16 runtime, in which case you can keep the existing runtime and license. Not 100% sure if you'd be able to use the v17 library though, but it's at least worth a shot.
Thank you, that sounds like an option. The library is for Step 7, not WinCC.
It doesnt help you. If the HMI project is integrated in TIA (most probably it is) with the PLC then the WinCC RT will still be compiled to the same version of TIA.
One way could be to separate PLC and HMI projects, and use the 'proxy PLC' to make the connection between the two projects.
A sidenote, the in TIA V18, the generated WinCC RT Advanced is actually V17 since that is the last version that is ever being made for Comfort and Advanced.
edit: Maybe mk42 is right, that you can generate a WinCC RT V16 with TIA V18. I am interested in how it goes.
Hi all, I really need help with this one. I'm at a complete loss... For months and months, I've had no problems with pressing a NEXT button to...
1,447
I've got this start screen where the user has to enter their username and password. The username and password feature works fine. However, I want...
1,443
Hello Thank you all for your support. I am actually experience same issues with TIA portal V17 update5 as well as V18. The problem is with the...
802
Hi, im having trouble with using web navigator in tia portal. I have installed both web navigator server and client in my server pc and web...
823
Hi, Didn't found an answer to this particular problem. As everyone probably knows if you use windows scaling of display crazy things happen to...
1,644
