TIA Portal / WinCC and windows scaling
Chireadan
Feb 2022
Poznań
Didn't found an answer to this particular problem. As everyone probably knows if you use windows scaling of display crazy things happen to objects in WinCC panels/apps, like broken/torn gauges scattered all around the window, misaligned text, and so on. When the screen scaling is set to 100% everything works fine. The problem is, that i'm an amateur photographer and i am working on 27" 3840x2160 (4K) display. When you set windows to 100% scaling (default is 150, I'm using 125) on display with such big ppi (above 200) you have to work in TIA with magnifying glass. Is there any way do display things in WinCC panels correctly with windows scaling other than 100%? Or I have to change screen resolution?
Cheers
73 de SP3AMA
Cheers
73 de SP3AMA
I'm not aware of a way to get WinCC to play nicely at scaling different than 100%.
Option 1: change screen resolution.
Option 2: use magnifier tool, but I imagine that would get really tedious
Option 3: Get a 2nd monitor with less dpi. I'm a huge fan of dual monitor setups anyway. Use Portal on the new monitor, then you can have documentation/whatever on the other monitor.
Hi all, I really need help with this one. I'm at a complete loss... For months and months, I've had no problems with pressing a NEXT button to...
1,448
We are rewriting software for a Simatic PLC/HMI originally made with TIA Portal V16. We will make use of a library that was developed for V17...
1,581
I've got this start screen where the user has to enter their username and password. The username and password feature works fine. However, I want...
1,443
Hello Thank you all for your support. I am actually experience same issues with TIA portal V17 update5 as well as V18. The problem is with the...
802
Hi, im having trouble with using web navigator in tia portal. I have installed both web navigator server and client in my server pc and web...
824
