WinCC SP1 V13
Mike5981
Jul 2016
Ireland
All,
I am developing a HMI on WinCC V13 SP1.
I am creating a log on facility for operators where the operator enters his username and password. Fairly standard stuff.
I am using a 'Control View'. This is dropped on to my test screen and when I click on it a logon dialog appears.
From here the users logon and password is entered and the 'Control View' populates with the operators log on details.
This works perfectly when I put the HMI application into 'Simulation Mode'.
However, when I download the application to the HMI I am unable to get it to work. When I click on the 'Control View' the log dialog appears without any problem. I am able to enter my log on details but my 'Control View' does not populate!!
Can anyone shed some light on this for me!! It is driving me crazy!!!:mad:
Did you download the user administration? its a checkbox you have to tick, as downloading the user admin can be a bad idea.
Thanks Chris,
Problem solved. During the download of the project to the HMI I had to enable the overwrite option for the User admin.
I knew it was something simple like that but its the simple things that catch you sometimes :mad::)
Hey folks! Just upgrading to Portal and completing install and got a querry. When you install WinCC, there are two DVD's. After the first DVD...
16,861
Hello, There is no Audit trail option for the TIA portal WinCC professional. It is kind of built in. For IO fields it is easy to do, but for...
4,512
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,053
which file I should install If I want to install only Sybase SQL database from WinCC V 5.0 SP1 CD.
1,626
Hi, I have a problem in WinCC V7.0 SP1. When I work in graphics designer and want to edit a C-action on a object the designer freeze. It is...
2,601
