WinCC Unified recipe issues
dbozic
Oct 2013
Zagreb
74
I started working with Unified panels and am experiencing trouble with recipes (or to be correct parameter sets).
I did check all the YouTube videos before asking here and was searching the forums but haven't find the answer and to be honest don't know where to look. Issue is that on the HMI i cannot create/delete or do anything with parameter sets.
I have parameter control view blocked with job id set at 999999.. (i believe this is max number).
On simulation everything works normally and as expected so I don't see programming error.
I use internal memory for recipes data(but have also tried usb where I can see some database was created).
Not sure do I need to do something on the real panel because as I said everything works in simulation..
It looks that something buggy was with TIA or something broke in the UDT in the PLC UDTs (had like 5 revisions so something maybe got broke in between).
I made a new PLC UDT and new parameter set, connected everything as before and now is working!
Leaving it for feedback, working on version TIA v17 so maybe the new V18 fixed some issues.
PS. Also now showing number 9999999999 in the as parameter set number but that seems normal as now create new button works and then it starts from "1".
So when there is no sets it seems that this number is shown..
Hi, I have just started with WinCC unified (v17) and there are alot of things I used on Comfort but now are not available. Currently I am finding...
2,845
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
62
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
77
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
153
I am creating a project with WinCC Unified v16 Upd6 (PC runtime) with an S7-1200. The communication is good between the PC and the PLC as I can...
210
