WinCC v6 Serial Port communication and Radio Frequency
husamothman
Jan 2006
United Arab Emirates
Hello,
I wish to animate objects on a WinCC screen in runtime So that when my project is activated, i will read data from the serial port and depending on the values read in, I want objects on the screen to flash, change colour, etc.
The thing is the Slave PLC, s7-200, is located very far a way. and i am the data is read and/or sent by Radio Frequency Transceiver at each side.
PC - Master:
- WinCC + RF Transceiver to COM port.
PLC - Slave:
- S7-200 CPU 224xp + RT Transceiver.
Any ideas on how making WinCC v6 work it out?
Regards,
Husam Othman.
I was wondering if it was possible to update WinCC through the serial port, without using a PLC.. Is that possible? if yes, can you please tell me...
2,021
Hello I am a university student conducting a project on making WinCC v6 talk to S7-200 CPU 224XP. The thing is: - Slave PLC is located a way from...
10,311
P
i want 2 connected serial [rs-232] device to wincc v5.1 plz.help me for driver or opc or converter device tank paya
1,973
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
35
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
51
