WinCCFlexible 2008
set-csg
Nov 2006
ILIGAN CITY
42
:handball:Hi Everybody,
I have a project in WinCCFlexible 2005. It will run in runtime software using the configurat5ion computer. But when I test it in WinCCFlexible 2008 it will not run. In both cases I am using S7-212 Siemens PLC. The setting in the SetPG/PC interface is still the same ( S7 ONLINE----PC/PPI cable((PPI). Is there any other setting that I will changed? Or any configuration that I will make?
Please help me.
set-csg
Hi
In WinCC Flex 2008 look at view> output and see if there are any errors listed
Hi
Do you have SP1 HF2 ?
If not download, install, re-convert the 2005 project and try again
There is known conversion issues in early version of WinCC flex 2008
Other than that I dont know
Hi, cjd1965
Thank you very much to your advice. I will try that, God Bleessed. By the way I dont have SP1 HF2 will you please tell me were to find and download it?
set-csg
Hello i encounter a problem to communicate between a simotion D435 and a winccflexible 2008 runtime. the communication was originally running, and...
2,620
Hello forum members. One of my customers wants to allow a programming laptop to access some PLCs and HMI through a firewall and is asking what...
1,521
Any one who know the problem ,Whenever I want to install my winccflexible always appear below message :(, '' Please restart Windows before...
2,495
I have developed a WinCC Flexible runtime in TIA V17 which is to display data from 7x S7-300 plc's and 1x S7-1500 plc. The runtime sits on a newly...
2,328
Hello everyone, In WF 2008 SP2 - I have a little problem,TOOL WINDOW and PROPERTY VIEW disappeared,I can not reopen them any more,is here any one...
1,530
