WinCCflexible and S7315-2DP
manmeetvirdi
Oct 2004
India.
750
Hi
I am trying to interface operating panel(TP 170B and spftware is WinCC flexible 2004 standard) Siemens plc S7 315-2DP.
In operating panel i have dedicated the rpm of a motor to say "DB 1 DBD 0".
Now to problem which I'am facing is how to access this location of operating panel to PLC that is "DB 1 DBD 0" corresponds to which address in PLC.
Communication is being done through Profibus between plc and operating panel.
Thanks in advance for valuble time of yours
regards
manmeet
It correspond exactly to that address.... DB1.DBD0
I assume that you will want to display this data in an output field, open up the properties of the output field and select the new tag icon, give the tag a name (#motor_rpm), select DINT or DWORD display, for data type you are using, then select 'range' = DB, DB = 1 DBD = 0, save and compile.
Paul
hanx for the answere PLucas
hi there PLucas !
Thanx my answere is "DB1.DBD0"
Silly isn't it
But anyway many thannx for your time
regards manmeet
I have developed a WinCC Flexible runtime in TIA V17 which is to display data from 7x S7-300 plc's and 1x S7-1500 plc. The runtime sits on a newly...
2,325
Hello i encounter a problem to communicate between a simotion D435 and a winccflexible 2008 runtime. the communication was originally running, and...
2,602
Hello forum members. One of my customers wants to allow a programming laptop to access some PLCs and HMI through a firewall and is asking what...
1,516
Hello everyone, In WF 2008 SP2 - I have a little problem,TOOL WINDOW and PROPERTY VIEW disappeared,I can not reopen them any more,is here any one...
1,523
hello I need help I have an RSView32 application with an older version I was converting an application of WinCC Flexible 2008 SP1 if you have a...
1,803
