Windows CE popup on PV+ after Printing
ElectricFreak
Dec 2009
Indiana
26
Does anyone know how to eliminate the message that pops up after printing from a PanelView Plus?
The popup has a header that says "Windows CE Networking"
The body of the message states "Print Job # on Queue \\Servername\Printer has finished printing. Size of job is ***** bytes"
Or If I cannot prevent this from appearing, how can I make the OK button larger, so it is not so difficult to select?
On a touch-screen only, PV+700 this ok button is so small, it is difficult to get without using something as a stylus, that can result in screen damage.🔨
If you can get access to the RA Knowledgebase (TechConnect contract needed) there is a technote with some attached files to modify registry.
This is needed as Windows CE is designed to provide by default the printing messages.
Technote #35179
- fuzzy logic
Dear Experts, I want to pop up a window automatically when a tag value becomes high. I am using FT View SE v8 & RSLOGIX5000 v16 Please tell me...
2,421
Hi, using FT6.10 on a PVPlus 1500 I'm created popup windows using the goto PB to activate the popup. On this popup I have some caution text for...
3,005
I was going to do a several popup windows, but seems just be able to have three windows open at any time, is it normal. The idea was to make...
7,501
Hello all I know it's a plc forum but i bet some of you may experience the same problem under window XP. Is there a way to configure something...
6,013
Hi everyone, I have an issue with installation of Studio 5000 33.00.02 DVD Media disc 2 with View Designer on Windows 11. After installation...
110
