Windows XP 32 bit and 64 bit, STEP 7
userxyz
May 2002
any
2,768
Hey,
I received my new PC @ work.
What should I install:
Win XP 32 or 64 bit ?
The IT are telling me that 64bit is good, but they are not sure that it will be compatible with the CP5611 card that we would put in a PCI slot. We need a 64 bit driver I guess,
Any suggestions ?
I suggest never try to install Siemens SW and HW to new OS before official release about compatibility from Siemens. Siemens SW change a lot of Windows components. If you installed Siemens, you have not Windows but Sindows on your PC.:)
hey
Wel I've tested it and can TELL U !!!
SIEMENS IS TOTALLY INTEGRATED NOT COMPATIBLE AUTOMATION WITH 64bit OPERATING SYSTEMS !!!!
Unpossible to install step7 v5.4.
5.3 could be installed with to many errors to trust the software.
PDM didn't work either,
and so on...
SO DON'T TRY TO INSTALL ON A 64bit operating system now !!
Hi I need PC Adapter USB Driver for windows 7 32bit. How can I download it?
1,203
Hi, I would like to know if any of you tried RSLinx Classic with a 64-bit operating system. We currently have a computer with RSLinx Classic but...
2,233
Hello I hope this doesn't count as advertising. In my search for a solution that doesn't involve virtualization I've stumbled across the plcs.net...
14,378
Hi, Has anybody had any luck running RedLion's Crimson 3.0's Emulator under a 64-bit Windows (7, 8.1 or 10)? Thank you
3,434
I'll keep this as brief as possible, but it is a long story. I've been programming 90-30's since the late 90's. Haven't used them much lately but...
4,798
