Wonderware 7.11 with Siemens S7 400 and Allan Bradley plc
shandra_ck
Jan 2005
Malaysia
63
I am having communication problem between a pc that installed with wonderware 7.11 to Allan bradley plc.
This pc originally was conected to S7 400 and allan bradley plc. The hard disk crach and I am not able to retrieve anything from there.
After reinstallation in a new hard disk, I am able to communicate with S7400 plc but the communication with Allan bradley could not be established. The communication is via ethernet.I already installed I/O server for Allan bradley (direct) and for S7.
I manage to find the existing configuration file for I/0 AB and load them. I still unable to get the signal from AB plc.
I do have the lic for I/o server.
I have tried the same setting with another pc, and with RS linx v2.2. From RS Linx I am able to go online to AB plc.
Can anyone advise me what setting was wrong?
Do I need additional license for RS Linx to communicate with Wonderware?
Thank you
Regards
Shandra
Wonderware 7.11
Let me simplified the problem that I face. I am having trouble to communicate between Alan Bradley plc 5 and Wonderware V7.11.
There is no signal from AB plc?
What are the steps should I take to troubleshoot the communication?
I did when through the manual and already setup the i/o server (direct) in wonderware, installed RsLnx 2.4.
The pc is running on Win98 se.
Please guide.
Thank you.
Regards,
Shandra
Hi Shandra,
Can you ping the AB plc from the wonderware PC?
In the I/O server configuration give the PLC a name rather than an IP address and add an entry in the hosts file to map the name to the ip address.
HTH
Mark
Yes, I am able to ping the AB plc. Yes, in the I/O server configuration I gave a name and map it in the host file. Wonderware is connected to 2 AB plc and 2 Siemens S7 400 plc. I didn't add the S7 plc in the host file. Is there any problem if I don't add? At the moment the communication to the S7 plc is working fine.
Thank you.
Regards,
Shandra
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,415
HI All ! I am having a problem . Please help me ! My Customer has a Siemens computer , the Operating System is WinNT WorkStation , there is...
8,306
Good morning guys. I'm posting here because I have a situation that I can't solve.. we are migrating from intouch 10.1 to 17.2 and we install...
1,646
Hi all, Got a client who has requested a SCADA system for downtime tracking and so on. Right now, they want to implement it as a standalone...
20
7,848
Hi, I would like to ask, does anyone of us have experience in communicating by ethernet between Simotion D435 and Wonderware InTouch? Is it even...
1,349
