Wonderware - Create a List Box to Record Faults
Ones_Zeros
Feb 2014
at work
367
Hey Guys
I have a Wonderware Scripting question.
I created a "Data Change" script that writes and stores the
faults into a text box so that I can save the last 10 faults.
The test script works fine when I test it on my laptop. I test it by manually inputting a fault and I can see that it writes to the text box successfully.
The issue that I seem to be having is when I make this live and in the event there is a fault. The faults are not being written into the text box.
So what could I check on the Wonderware tag?, is there a setting that flags
a data change bit?
Here are some screen shots:
Data Change Script
List Box - Faults
If I type in a 99, It will put "99 - Lost Compress CE Vib Transmitter" in the text box
Tag Setup in Wonderware
A 'Data Change" script is the correct method in triggering a change in a bit..right?
thanks again you guys for the help!
A Data Change script will execute whenever the value of the trigger tag changes, if that's what you're asking. I don't have any WW software with me at the moment, or I'd try running your scripts.
I have to ask why you aren't simply using the built in InTouch alarm system to handle fault reporting?
Thanks Bit_Bucket_07
Thanks for your feedback...I also utilize the WW alarm system.
The script just allows us to look back at the last
say 10 faults that occurred on a drive or centurion
without digging through the alarms.
It’s weird...when I run the script as a test on my laptop
The script works great. When I look at the last fault
that has occurred, sometimes it doesn’t get written into
the text box, kinda like WW didn’t see the change in status.
I did check and I do have that particular
Fault configured into the script.
I guess that’s why I was second guessing myself
Wondering if the data change script was the correct
Method.
Thanks for your help!
I am trying to add a TCPIP server group to integrate a Schneider M221 PLC in to Wonderware. When right clicking on the Operations Integration...
436
I was given some example code but I can not get the function to show up in the System Platform script. The dll import is successful but I'm...
2,052
Hello! I am using Wonderware for past six months but still haven't fully cracked it yet! In my current application, on the alarms page I have...
1,212
Hello and Happy New Year Everyone, I'd like to create an Excel file from a template via a script in Galaxy IDE. Maybe somebody has a simple...
4,880
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
169
