Wonderware DAserver ABCIP issues.. cycling tag database downloads.
Nova5
May 2013
Northern Snowball
566
Having a Issue at a site where WOnderware can seemingly connect to the PLC and all shows good except its locked into a loop for downloading the tag database.
Database change detected..
Download Database.
Download Complete..
Database Change detected..
Download Database
Download Complete.
Database change detected...
on and on. CIP setting lowered from 4 to 2. THe other DAserver also ABCIP does not show this issue.
I can in the diagnostics section of the SMC watch the tags be read show good for a second, show bad a moment later, then show DELETED. Get read, good, bad, Delete.
PLC is a AB L71
WW 2012.
A different project accessing the same DAserver and PLC does not have these issues. Both projects on the same PC.
Also the field deployed copies of the project work just fine on their PCs where they have their own local DAServers.
Settings match between the working DA servers and the trouble dev stations DAserver settings.
Indicates it local to the dev station itself. Anyone have any thoughts on what could be causing it?
I am trying to break the link between a wonderware tag and a tag in RSLogix. No matter what i do to the tag in the PLC the wonderware is holding...
1,788
Hi, I have a Legacy project that I have converted from Intouch 7.1 to intouch 11.1 now running on windows 10. I have also uprevved the DA Server...
3,587
Hi all wonderware users As I'm new to this and cant find a solution for the error message STS=1E I'm using a Intouch v10.5 connectet to...
3,556
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,435
Hello all, I am developing HMI screens for a Wastewater Treatment Plant which is using Modicon M580 PLCs that are running Unity Pro XL version...
3,872
