Wonderware Historical Data Server (hd.exe) using lots of processor
phuz
Jun 2008
Mohnton, PA
1,044
I just ran into an issue where the InTouch historical trending is not functioning properly, and when I look in task manager, the historical data server (hd.exe) is using almost 20% CPU, compared to almost nothing when it's functioning fine. My trends are completely black and do not show data. If I force the hd.exe closed and restart InTouch, it might start working, but it does not last long before it behaves like this again.
Any ideas?
Any ideas?
You aren't running out of disk space, are you? That used to be a potential problem, when HDDs were smaller than they typically are these days. Maybe you're writing data to a bad sector? InTouch trending will do this with a corrupted file. Having a file with a future hour after a change in DST will also cause this problem to occur.
lol, no disk space is not an issue.
I had actually tried deleting the historical files for that day, and it worked briefly, but back to the issue. Hmmm...maybe if I delete everything since the weekend (DST change), it will be OK, but that hardly seems like a fix, and more of a bug.
DST is a bug. Wonderware offers some scripting work-arounds, but they're kind of complicated. It's difficult to make sense of a single hour occurring twice in the same day.
I am using Historical Trends please refer the attached image. I described the slider as s1, s2, s3, s4. I need to view only the selected pen in...
1,249
Hello, I am working on a SCADA system using Wonderware Intouch 2014 R2 and have a small glitch with the historical trend feature. Every time I...
2,865
Hi, I am new to wonderware, I am having a question that is it possible that wonderware Historical trend can provide six month trend? I am having...
3,354
I tried to find some information using the search engine and I couldn't find anything helpful, so I'll post this here. I've been assigned to a...
7,150
Hello folks, Under our current bleach plant wonderware HMI program there's a bunch of historical trends as well as real time trends. What I need...
14,251
